D2 Problems ???
D2 Problems ???
Showing 1 to 6 of 6 results
MyOlD2
Send a private message to MyOlD2
I am having a steering problem with my D2 5J .It is all i can do to make it turn left when going down hill.
When going up hill it will turn left with no problem.Any help with this would be appreciated.
Sun, May 5, 2013 8:38 AM
Thank you received: 23
Sounds like you might need to adjust your left brake
Sun, May 5, 2013 8:40 AM
n7gxz
Send a private message to n7gxz
What procedure are you using to turn left when going down hill? The steering is backwords going down hill. To turn left you release the right clutch.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Sun, May 5, 2013 9:56 AM
MyOlD2
[quote="Neil"]Sounds like you might need to adjust your left brake
Neil[/quote]
Left brake adjusted all the way.I guess replacing brakes is quite a big job.
Thanks for your suggestion.
Sun, May 5, 2013 10:46 PM
MyOlD2
Reply to n7gxz:
Kevin
[quote="n7gxz"]What procedure are you using to turn left when going down hill? The steering is backwords going down hill. To turn left you release the right clutch.
Kevin[/quote]
To turn left going down hill i pull back on left lever and press on left brake.I thought this should stop the left track.
When going up hill i just pull back left lever and it turns left without pressing left brake.
I will try your method .Thanks for your response.
Sun, May 5, 2013 11:01 PM
That technique of pulling the opposite side steering clutch only works if you have a load pushing you or the downhill is very steep.
Might check that there is not oil collected in the steering clutch compartment so the brake drum is oily. The compartment can be flushed with solvent to remove accumlated sludge and then filled with enough solvent to clean the drum as the tractor is driven forward and back while applying the brakes lightly. if that does not work and there is no more adjustment, then the final drive must come off to replace brake lining.
Mon, May 6, 2013 5:11 AM
MyOlD2
[quote="ccjersey"]That technique of pulling the opposite side steering clutch only works if you have a load pushing you or the downhill is very steep.
Might check that there is not oil collected in the steering clutch compartment so the brake drum is oily. The compartment can be flushed with solvent to remove accumlated sludge and then filled with enough solvent to clean the drum as the tractor is driven forward and back while applying the brakes lightly. if that does not work and there is no more adjustment, then the final drive must come off to replace brake lining.[/quote]
Thanks for the information.I will try your suggestions.
Mon, May 6, 2013 6:08 AM
