Zenith carb flooding
Showing 1 to 6 of 6 results
grayrat
Send a private message to grayrat
1936 RD4 pony zenith carb keeps flooding. If i manually turn off and on (regulate fuel flow) the fuel line i can keep it running. I've replace the float and needle / seat no change. Any suggestions would help.
Fri, Apr 12, 2013 1:02 AM
Did the seat happen to have a gasket on it?
Then did you adjust the float level?
Is there any rust or crud that seems to be in the float bowl when you take it off?
Fri, Apr 12, 2013 1:21 AM
Reply to drujinin:
some pony carbs get a beating when things go awry.
I have seen float bowls with badly dented in ends and sides so much so that they would catch the float and stop it rising or falling, thereby, the fuel does not flow or will not shut off as needed.
Float should sit level with the top cover when it is held upside down.
Fri, Apr 12, 2013 7:35 AM
grayrat
Reply to drujinin:
[quote="drujinin"]Did the seat happen to have a gasket on it?
Is there any rust or crud that seems to be in the float bowl when you take it off?[/quote]
no gasket and yes there was crud between the fuel inlet and needle so i flushed and dipped the upper cover. float level was good and moved freely. The fuel line is gravity feed is there a pressure limit on the inlet?
Sat, Apr 13, 2013 8:49 AM
Reply to grayrat:
Probably the crud is coming down the line and will be a continous problem.
Pressure?
If the fuel tank is a few inches higher than the carb, I would have to assume the pressure would not even be in the psi range??
Maybe 1/4 psi max?????
Sat, Apr 13, 2013 9:32 AM
Soapy
Send a private message to Soapy
Reply to grayrat:
Have you removed the pony gas tank, and cleaned it thoroughly? If not, you will be fighting the float problem forever.
Sat, Apr 13, 2013 10:18 AM
Thank you received: 19
Reply to Soapy:
I have overcome some troublesome tanks by converting the drain plug to mount a filter sediment bowl w/shutoff.
Sat, Apr 13, 2013 11:14 PM
Earlcoate Charity Open Day
