cat 3208 engine
cat 3208 engine
Showing 1 to 7 of 7 results
DDDfarmer
Send a private message to DDDfarmer
Hi guys, I am going to go look at an mid 70's tractor with a 3208 cat engine. the posted add was saying that the engine is not running. Just wondering if there is anything I should really look at on this motor. Online search mentions problems with the rack sticking, are there any tricks to fixing this or just clean up and lube?
Let ya know how it looks.
Mon, Mar 25, 2013 6:01 AM
Delta Dirt
Send a private message to Delta Dirt
Sounds like you may be looking at a M-F 1805-------I ran one for several years.
The 3208 was not one of the more durable engines CAT produced----high rpm----low torque engine design that needed to be operated at upper rpms and not lugged. Bought mine cheap knowing its faults------so no reason to complain.
At the same time----I became very familiar with the insides of the 3208; before installing a CAT rebuilt engine.
Hang on for some advice from the "pros" here--------but based on my experience, I would place no more value than the CAT core exchange value without seeing it run. Over fuelling was one of the major down sides of the 3208.
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Mon, Mar 25, 2013 9:37 AM
60steve
Send a private message to 60steve
Reply to Delta Dirt:
Delta Dirt
I've been looking to install a 3208 in a later model Ford pickup truck. I want to get rid of the gutless 6.0 liter engine and replace it with something caterpillar. Does anybody have any input?
Mon, Mar 25, 2013 10:07 AM
D349
Send a private message to D349
Reply to 60steve:
G'day.DDDfarmer 3208's have a sleeve metering fuel system which cat used on 3200 and 3300 engines. The entire fuel pump housing and governor housing are full of fuel at transfer pump pressure, they certainly dont like water in the fuel and therefore need well maintained water traps between the tank and pump. The transfer pump is a little gear pump in an aluminium housing at the front of the fuel pump assembly, which can wear and create low pressure, should be about 30psi. Fuel pump has 12v or 24v fuel shutoff solenoid whichsits upright on the top cover and works on the rack, you could possibly take that of and check that rack moves freely other wise you can't do a lot with out doing a full job on the pump.
60steve. Its a big heavy engine to put in the front of a Ford pickup 10.4 lt 636cu in
Kevin
Mon, Mar 25, 2013 6:27 PM
DDDfarmer
Reply to D349:
Kevin
Tractor is a white 4-150 and still waiting for a reply from the seller. Maybe its already sold :noidea:
Mon, Mar 25, 2013 8:35 PM
Soapy
Send a private message to Soapy
Reply to 60steve:
You must have a 1-ton front axle, and remote mount the oil filter. These are only 200hp. A better choice would be a 12 valve 5.9 Cummins. 360hp using 100hp injectors, and run the pump up.
Wed, Mar 27, 2013 9:44 AM
60steve
Reply to Soapy:
I thought about the cummins too. I wish that there was a cat engine that would work in such a scenario. I have a manual transmission. All it would need to do is bolt to that and fit in the engine compartment...
Wed, Mar 27, 2013 10:53 AM
Soapy
Reply to 60steve:
Check out a 3116. I have no idea about the dimensions of this engine that is used in 1.5-2 ton trucks. You do know, that to remove the engine from your Ford, you will have to take the cab off the chassis. This is the easiest way to do any major work to the 6.0. Even head studs and gaskets.
Wed, Mar 27, 2013 12:58 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
