22 Cat priming oil system ?
Showing 1 to 9 of 9 results
nw4evr
Send a private message to nw4evr
I have two gas engines from a 22 Cat , each been drained of oil for 2 years, and the oil pans were off and cleaned out, valves adjusted but that is all i did internally. I am ready to start up shortly. I was just going to put in 30 non-D oil , " give them a whirl" and hope for the best.... one was a runner 2 years ago, other one, have no idea last time it ran, but it was not stuck and the exhaust was covered up.
My dad says ".... you had better prime the oil system before first start or main bearings and other areas could be damaged before the oil gets where needed" .. I suppose that is a valid thought, then i asked him how to go about it, he had no idea, just something that he recalled from somewhere in his past experiences, then he adds "... better check with " your guys in the know," on how to do this" .
So that is what i am doing, looking for input..
keep in mind everything is back together. suppose i could pour oil over the valves with the cover off while turning it over,, or tap into the oil line in the side and pressurize somehow..???
all input would be appreciated, even " install oil and go for it" if priming is a " non issue" in your experience.. will be interested what comes out of this... Dave P.
R2 5E 3542 SP, 22 2F, 22 1J
Fri, Mar 8, 2013 12:45 AM
Tap in the oil manifold and pump the oil into the engine as you are rotating it. A pvc pipe "bomb " that you can pressurize with air works well. Local mechanic had a water type fire extinguisher that he used to prime all his overhauls before starting. He could put all the oil in at one time, fill it with air and control the flow with the valve.
Fri, Mar 8, 2013 2:11 AM
Sure beats the option of pouring oil over everything, taking the plugs out for no compression, then cranking it, till your arm falls off!
Fri, Mar 8, 2013 2:49 AM
Mike Meyer
Reply to drujinin:
What I do is remove the spark plugs and slowly drag the old girl in reverse with another tractor, in a few yards you will see your oil pressure gauge working, and if I'm in doubt about my oil pressure gauge I unhook the oil line and actually look for the oil being pumped out the line under pressure, then I close the oil line and fire the tractor up. On my recent 2 Ton fire up I'd previously rolled the motor over by hand with the rocker cover off and could see the oil being pumped out over the valve train, you should check this once you get the motor running.
Most important thing about starting a motor for the first time is knowing how to stop it if the throttle is jammed open, or something is wrong, test your magneto On / Off switch, and in the case of diesel motors have the air intake pipe open so you can slap a piece of plywood over it to starve the motor of air.
Good luck, there is nothing better than hearing a old Cat. motor fire up for the first time.
regards
Mike
Fri, Mar 8, 2013 3:21 AM
Dan Pratt
Reply to Mike Meyer:
regards
Mike
I am going to try the pressure bottle idea like the fire extinguisher jug. I will just tap into the oil pressure gauge line and let er flow. Spinning the engine over by hand with no spark plugs may be a good idea.
The pump in those when full of oil is submerged, I believe, so it will prime fast.
Fri, Mar 8, 2013 4:50 AM
Reply to Dan Pratt:
I have used a cheap old plastic garden sprayer --disconnected the wand and clamped the hose to the oil line
it seemed to work quite well.
Fri, Mar 8, 2013 4:54 AM
thomas84
Send a private message to thomas84
Reply to dpendzic:
Dave, I would pull the plugs and crank it a few times, Thats what I did on my 22 and didnt take much cranking to have oil flow and the needle going up on the gauge. Isnt your son in wrestling? have him do a little training by cranking it for you... he will be able to pin anyone down👍
Robert
Fri, Mar 8, 2013 7:13 AM
ErnieinTucson
Send a private message to ErnieinTucson
Reply to thomas84:
Robert
Hi all
I use a refrigeration recover can, put about one gallon of oil in , add air, attach to oil gallie, with about 20psi, go to go.
Ernieintucson
Fri, Mar 8, 2013 9:03 AM
Kelly
Reply to ErnieinTucson:
Hi all
Ernieintucson
these are all good suggestions and ideas, some I have used myself. But here what caterpillar has to say about eliminating the dry start. Although is for the mentioned engines please make note of the last paragraph.
Kelly
[attachment=16518]Lub%Rebuilt% engines.%no%dry%starts..jpg[/attachment][attachment=16519]Lub%Rebuilt% engines%tool_2.jpg[/attachment]
Fri, Mar 8, 2013 2:20 PM
nw4evr
Reply to Kelly:
Kelly
So it is a good idea to prime, and my dad was right. Good thing i asked about it.
Thanks to all for the many different methods to accomplish it! I will probably use a composite of many methods, first jeffs advice to remove plugs, and then roberts idea to let my son crank on it ( that is probably the BEST and cheapest idea for me, as he is now 6' 7" and over 300 lbs, besides, he is always asking, " hey dad, what can i do to help?" !!) 😆
looking under the valve cover for oil flow is a good idea i had not considered, and i was not aware they primed so readily and actually build pressure on the guage, by just spinning the crank.
Thanks again. If the initial carb settings work out ,it should " cough into life" shortly.
Dave
Tue, Mar 12, 2013 1:01 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
