Fresh Start on Cat Ten Engine
Showing 1 to 10 of 21 results
Cysco
I moved the Ten Engine I was working on to a holding pattern and rolled the spare engine out of the back room and proceeded to take it apart. I found where some work had been done. The valves looked much better in the seat areas. The pistons are .040 over and appear to be in good shape. The pins are tight but need checking. There was a drag while turning the crank over. The rod bearings looked okay but when I removed the crank it didn't take long to see the problem. The rear bearing had come apart. The crank may get by with a polishing and replacing the main bearings looks like the worst issue.
I believe my best bet is to use this engine and find some Main bearings and rings. The other engine had to many problems.
Any thoughts, suggestions or recomendations ?????
Thanks.....Bill
Mon, Feb 18, 2013 7:41 AM
Cysco
More Pictures........
Mon, Feb 18, 2013 7:45 AM
chriscokid
Reply to Cysco:
Compared to your other engine i would most definitely use that one over the other!
Mon, Feb 18, 2013 8:30 AM
Reply to chriscokid:
Cysco,
Wow, very neat and organized shop, and a Coke, no beer. Something's wrong with this photo. 😊
Tue, Feb 19, 2013 3:27 AM
Inter674
Cysco,
no dirt floor, no open/missing doors, no sparrow's nests, no smashed walls and windows, no stacks of parts, no tools strewn about, no oil or grease stains anywhere......
What sort of a man's shed is this 😊
PS wish it were mineπŸ‘
Tue, Feb 19, 2013 6:12 AM
Mike Meyer
Cysco,
[quote="[email protected]"]Cysco,
Wow, very neat and organized shop, and a Coke, no beer. Something's wrong with this photo. 😊[/quote]
I think Cysco must be a Surgeon or Dentist in his or her spare time!πŸ˜† I do envy your ability to keep track of parts and tools, and neat shop, I'll show you a photo of my current workshop, you may not need a napkin for your Coke can.πŸ˜†
regards
Mike
Tue, Feb 19, 2013 6:49 AM
old-iron-habit
Reply to Mike Meyer:
regards
Mike
I have a lot of respect for you outside guys that turn out the work you do without the benefit of a dry shop also. My hats off to all of you. Now, fully embarressed I got to go start cleaning the garage.
Tue, Feb 19, 2013 6:58 AM
regards
Mike
[quote="Mike Meyer"]I think Cysco must be a Surgeon or Dentist in his or her spare time!πŸ˜† I do envy your ability to keep track of parts and tools, and neat shop, I'll show you a photo of my current workshop, you may not need a napkin for your Coke can.πŸ˜†
regards
Mike[/quote]
Mike, you are a man of obvious class. Red wine with your 2 Ton. What cheese do you recommend? Ray
Tue, Feb 19, 2013 7:17 AM
Cysco
regards
Mike[/quote]
Guys,
I learned to pick up things while spending the last thirty years build homes.......have you ever stepped on a nail.....man that hurts !!!! But I am glad you like my shop as it took me several years to build. As far as a hole in the wall....that piece of sheathing behind the drill press is hiding one. The hydraulic press sent a piece of steel flying through it while I was pressing out bearings.
I started outside working on old cars so I know how hard that is to do.......I think I still have a few gravel marks on my back.... 😊
But do ya see anything amiss on the Ten parts.......I am trying my best to get it done before show season starts but things keep cropping up making it difficult.
Have a good evening....Bill
Tue, Feb 19, 2013 8:48 AM
JasonPayneCrawlers
Reply to Cysco:
Guys,
I know how that is. But I can say if it was easy then we would not be able to get are hands on themπŸ‘πŸ‘
Tue, Feb 19, 2013 9:52 AM
Cysco
Reply to JasonPayneCrawlers:
Right you are Jason........it is part of the fun in these old Cats !
Bill
Tue, Feb 19, 2013 5:07 PM
Booleroo 2025
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
