Sixty Oil Presure Gauge Repair, Thanks Wally
Showing 1 to 7 of 7 results
Tim R
Send a private message to Tim R
I posted wanting help to have my Sixty oil pressure gauge rebuilt. After calling a few guys and finding a $500 est. to repair.
Wally posted a reply and got me started on doing it myself.
I took apart the worst one I had for practice, then took apart the better one that did work but the face was almost gone.
I took the face to a sign shop and the first guy couldn't get the scale right with 3 tries so to another guy and he did it right the first time.
I cleaned a lubed the watch type gears in the gauge, then put the face on. I then applied air with a air regulator to 30 psi and installed the needle on the rebuilt gauge. I checked the calibration from 5 psi to 50 psi and it is very close with in 2 psi.
I do have some extra face decals for $5 each if any one wants to try it.
Tim in Omaha
Tue, Feb 12, 2013 8:55 AM
Mike Meyer
Thanks for the photo's, you have done a brilliant job there, how do you dismantle the face?
thanks
Mike
Tue, Feb 12, 2013 5:07 PM
Reply to Mike Meyer:
thanks
Mike
What trick did you use to pull the needle?
Without a "needle puller" it can be tough to pull the sticky ones without damaging the bearings.
Tue, Feb 12, 2013 6:39 PM
droptube
Send a private message to droptube
Reply to drujinin:
Hi Tim, I would be interested in 10 gauge faces if you have them. Thanks Scott
Tue, Feb 12, 2013 11:02 PM
Moulding
Reply to droptube:
I am interested in the gauge decals as well ,thanks scott
Tue, Feb 12, 2013 11:11 PM
chriscokid
Reply to Moulding:
I would like two as well if avaliable.
Wed, Feb 13, 2013 1:44 AM
Tim R
Reply to chriscokid:
Guys I can get more printed the set up is done. You can email me for my address. [email protected]
The needle pulls kind of hard, pull it before you remove from the outside housing helps. I used a needle nose pliers.
The glass bezel is remove by first running a single edge razor blade around it, then a small puddy knife, then the gasket scraper, buy this time is is almost loose.
I pressed is back on using a large socket in my vise.
Please let me know how many deals you guys want by Sunday and I wil get them ordered next week. Tim
Thu, Feb 14, 2013 10:17 AM
JasonPayneCrawlers
Reply to Tim R:
I would take two.Thanks
Fri, Feb 15, 2013 10:21 AM
Chapter 2 The Link Club's AGM
