D8 2U roller and sprocket weld-up repair mig wire suggestions
Showing 1 to 10 of 11 results
reclineaholic
Send a private message to reclineaholic
I have the info posted by edb in his "undercarriage reclaiming" thread and I'm going to try repairing my bottom rollers and sprocket. I want to use a mig at least for the rollers because I want to do them automated on a lathe so I'm looking for an acceptable mig wire to use.
I've measured the rollers and some have some narrow areas that will need 3/8" build up but most need 1/4" build up.
The welder is a Lincoln 255 amp mig welder so I don't want to go over a .045" wire size.
I've been looking at Lincoln's Lincore line of mig wire and the "Lincore M" wire seems to be the closest to what Caterpillar calls for in their conservation articles but Lincoln seems to lean more toward the "Lincore 55-g" which is more appealing to me because it's cheaper to buy and it produces more useable material.
Looking for suggestions for wire type to use or not use, I don't mind so much if it wears a little fast but I don't want it so soft that it mushrooms and rolls off nor do I want it so hard that it cracks and chunks off.
This tractor will be used in fairly steep rocky terrain if that makes a difference.
Mon, Feb 4, 2013 1:42 PM
n7gxz
Send a private message to n7gxz
Question for you, how are you going to work the ground? Are you setting up a slip ring? You don't want to flow the ground through the headstock bearings.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Tue, Feb 5, 2013 8:24 AM
reclineaholic
Reply to n7gxz:
Kevin
[quote="n7gxz"]Question for you, how are you going to work the ground? Are you setting up a slip ring? You don't want to flow the ground through the headstock bearings.
Kevin[/quote]
Good point, I hadn't really thought about that but I definetly don't want the ground going thru any bearings... It's not going to turn very fast, one revolution in 4 to 5 minutes, and the duty cycle on my welder is probably going to require me to stop for a couple minutes after each revolution... Maybe just let the ground wind around the tail stock one time and then fix it while the welder is cooling?
Sent an email to Lincoln this morning to find out what wire they suggested for this job, got an automated answer a few minutes later, it said they would have a tech try to answer my question within two days. Well I'm not very patient so I called their main office and asked if there was someone who could help me pick a mig wire for a specific application, they connected me to a tech that suggested Lincore 55-G as long as I didn't go over 3/4" thick so I ordered some from weldingsupplies.com...... Just checked my email, and there was one from a Lincoln applications engineer and he said to use Lincore 33 ?? So much for a final answer.
Guess I'm gonna stay with the Lincore 55-G unless someone tells me they tried it and it didn't work.
Tue, Feb 5, 2013 10:29 AM
callan
Send a private message to callan
Reply to reclineaholic:
Kevin[/quote]
hi reclineaholic, you may want to invest in making a waterbath and a set of rollers so that you can build up the rollers without the need to
fully dissasemble them.
i used a lincoln 400 amp to do the job and just standard MS copper coated wire. yes i am sure its not ideal but i was at the end of my tether with money and figured well bugger it, I'll give it a go.
i have done about 40 hours now and cannot see the slightest bit of wear on the rollers.
ditto on welding in the lathe, though you would be able to make up a set of polyethylene soft jaws to grip the roller and effectively isolate the roller from the chuck if you wanted to.
i made a jig that would spin the roller at a constant speed while being in a water bath out of bits and pieces round the house. if you have a lathe you would be able to do the same.
my guess would be that the best rpms were about 0.7-.9 rpm for a roller that is approximately 200mm in diameter.
for earthing, i used a 15 dollar magnetic earth clamp, with a c shaped bracket i would tack welded to each roller to allow for a flat surface. worked well.
i used a windscreen wiper motor to drive one roller while the other was simply a free spinning roller.
the best beads were laid with the roller rotating away from the gun, with the gun pointing uphill, and zig zagging about a 15mm wide bead along the length of the roller. i canpretty much guaruntee you are going to be working at at least 200 amps as you need the heat to evaporate the water off otherwise the weld will sputter. i am pretty sure i was welding at around the 270-300 amp range
took a bit of learning to work out the best way, so be ready for a couple of days welding. holding the welder still and doing single line beads was pretty messy in the end, but give it a go and see what works best for you.
as with everything,theres always more then one right way.
hope this helps. : )
Tue, Feb 5, 2013 1:10 PM
reclineaholic
Reply to callan:
Just a follow up in case anyone else is looking for something to weld up rollers.
The Lincore 55-G hardface mig wire came yesterday and I got one of the rollers welded up with it. It was very user friendly, I just set the voltage and wire feed speed per the spec sheet and once I got the lathe speed dialed in the welds looked pretty good, they are wide, flat and smooth. There's quite a bit of splatter but don't think that will cause any problems.
[attachment=16171]2013-02-08 16.50.01.jpg[/attachment][attachment=16172]2013-02-08 20.13.56.jpg[/attachment]
Sat, Feb 9, 2013 9:52 AM
deckert d69u
Send a private message to deckert d69u
i can see i'm going to have to try that.I did 2 last year for my D6 ,all by hand this looks better and should take less time.
good job!
Les
d6 9u dozer
Russel hiway patrol no 1
Wabco 555 grader
superA farmall F 12,F 20 and various pcs. of rusty red tractors
Sat, Feb 9, 2013 10:08 AM
Nice!
Have you checked the bores to see if you have any distortion?
Sat, Feb 9, 2013 1:07 PM
Nice!
I'm not sure, but the 2nd weld looks to be flatter than the 1st?
Either way, nice job!
Sat, Feb 9, 2013 7:57 PM
D349
Send a private message to D349
Reply to drujinin:
G'day. When I was an apprentice in a Cat dealer in the early 80's they had the old rebuild equipment that used what is called submerged arc which used a mig type wire and a powder flux running out of a hopper and totally sheilding the arc as the idler was turning very slowly, an operator stood there and chipped of some of the flux that hardened over the weld and monitored progress and adjusted. When the job was done the idler would be covered up to cool slowly, the idler was pre heated with oxy before welding started to manage distortion and I think the later hollow type idlers would need a small hole put in the side of them. I only ever saw a couple sets of rollers done because of cost I think but distortion and bearing retention was a potential problem. I think the consumables where lincoln products. The equipment was quite old then.
Kevin
Sun, Feb 10, 2013 11:07 AM
reclineaholic
Reply to D349:
Kevin
[quote="ccjersey"]Nice!
Have you checked the bores to see if you have any distortion?[/quote]
The roller pictured needed to be built up 3/8" and had .020" shrinkage on one end and .015" on the other, it had to be bored before reassembly. I just finished another roller that only required 1/4" build up and it only shrunk about .001" I honed it with a cylinder hone and it reassembled with out a problem.
[quote="drujinin"]I'm not sure, but the 2nd weld looks to be flatter than the 1st?
Either way, nice job![/quote]
It is flatter. Thought I was getting better with practise but I've done two more and the second weld is still the best of the four so it was just lucky I guess. lol
Sun, Feb 10, 2013 12:18 PM
Tim Matthews
Send a private message to Tim Matthews
Well done ! Wire feed cuts the time more than half . Looks to me 55 is harder than 33 .
Only draw back I see is its only recomended for 3 layers without some heating.
Much as your laying down with each pass 3 ought to be plenty.
Was it much trouble to cut out distortion?
Tue, Feb 12, 2013 8:19 AM
