Another Cat Ten Update
Showing 1 to 9 of 9 results
Cysco
I received the last four bearings in the finals and steering clutches. Some were not bad on the checkbook but a couple made my knees buckle a bit ! 😊
The rollers,Frames and a lot of smaller parts were painted this past week. Started work on the water pump and had to replace the shaft. I need a source for the packing...any suggestions ?
Also I have a two pairs of roller guards but they are different sizes. (see picture) I can make another matching pair but which pair do I make ?
Let me know your thoughts....Bill
Thu, Jan 10, 2013 10:33 AM
There are a couple of Threads on here from the past year on water pump packing.
I know of at least one on the 15 and I think the other was on a 30?
Anyhow I have found "Valve" packing right off the shelf at the Hardware Store gives good life.
I know in the above threads one guy recommended McMaster -Carr as a source.
Thu, Jan 10, 2013 7:06 PM
chriscokid
Reply to drujinin:
Bill,
Here you go on the packing: http://www.mcmaster.com/#pump-packing/=kz6mci
or let me know how much and what size you need, i am sure i have some in stock.
Fri, Jan 11, 2013 1:19 AM
Cysco
Reply to chriscokid:
Bill,
Thanks Erik and Jeff....did a little research and will have packing by the weekend...McMaster_carr is fairly close.
Have a good evening......Bill
Fri, Jan 11, 2013 7:14 AM
janmeermans
Reply to Cysco:
Not really a normal source for us tractor guys, but I bought 1/4" Flax propeller shaft packing at West Marine which is working fine in my PV 15 water pump. I know you have located some but I'm thinking of others down the road who may want it.
Jan -CAT 15 PV 7207
Fri, Jan 11, 2013 11:45 AM
chriscokid
Reply to janmeermans:
Jan -CAT 15 PV 7207
Bill,
After looking at your picture of the front roller gaurds, it would be my guess that with only a 1/2" differance, i would make which ever set matches up with the rest of the lower rock guards.
I see no reason for the larger cut out other than if the idler was changed out for one with a larger dia. hub?
Fri, Jan 11, 2013 7:16 PM
janmeermans
Bill,
FWIW, I measured mine on a tractor with approximately 50% undercarriage at 9-inches so I guess it does not make a lot of difference. They are hidden by the rest of the guards. - Jan PV 7207
Sat, Jan 12, 2013 12:52 AM
Cysco
Bill,
[quote="chriscokid"]Bill,
I see no reason for the larger cut out other than if the idler was changed out for one with a larger dia. hub?[/quote]
Erik,
The picture is deceiving. The difference is a little over an inch so that led me to believ as you mentioned either a larger idler or maybe for another model. I am going to pick out the best ones and make a matching pair. Thanks!
Also Cassie said it would be okay to use her Ten at the show .......now that puts the pressure on me to get it done !
Have a good evening....Bill
Sat, Jan 12, 2013 8:17 AM
Cysco
janmeermans, I think you are right....making a matching pair is the best way.
Thanks for your help....Bill
Sat, Jan 12, 2013 8:18 AM
Pat in WI
Reply to Cysco:
Bill,
I'm visiting family in Wisconsin.
When I get back I will measure my idler guards. I still have lots of the graphite packing left and will send you what I have.
Pat
Pat in WI
Sun, Jan 13, 2013 7:59 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
