Eisemann magneto question
Showing 1 to 10 of 22 results
Mike Meyer
Thank you received: 5
I bought a Eisemann G4 Edition 2 magneto off Fleabay recently for my 2 Ton restoration and in the process of trying to sort out a intermittent spark problem noticed the small distributor disc which is mounted on the large geared cog inside that magneto do not have their "R" timing mark in the same spot, in fact they are about 150 degrees apart.
Not being a maggy person at all I thought I'd ask the question here, having not found the answer after doing a search of old threads. I've had the 2 Ton running happily on this magneto a few times but only after pull starting it, except once when I was able to crank start it, and yesterday when it wouldn't spark consistently or at all, on #1,3 and 4 cylinders, saw me busy once again cleaning and double checking the points, distributor disc and carbon pick up brushes, it has new Autolite 3077 spark plugs and new copper wire leads.
I know I should probably send it off to a proper maggy expert, but that will take 2-3 weeks minimum, and when I noticed the timing mark "R" not lined up on the large gear, and the distributor disc, it got me wondering which "R" I should have been using to time the maggy to #1 cylinder, the "R" on the large gear, or the "R" on the distributor disc which is about 150 degrees in advance of the "R" on the gear, because I had been using the "R" on the distributor disc up till now, but when I looked at a old parts G4 Edit. 2 magneto I have I noticed it's distributor disc has no "R" on it, or any timing marks at all, so I'm a bit stumped as to how that magneto got timed, you would have to use the large gears timing mark.
Do I use the "R" on the large toothed cog to time the magneto to cylinder #1, or the "R" on the smaller distributor disc which may well not even be the original? The small white dots you can see in these photo's are marks I put there yesterday using "White Out" just as temporary timing marks, hopefully you can see the official stamped "R" timing marks, it's roughly at 6 o'clock on the large gear.
This 2 Ton has been painted prior to mounting the magneto, and after reading one of Old Magnets posts he mentioned making sure the maggy was earthed well, and so I wire brushed off any new paint on the base of the maggy and the mounting pad on the motor though I haven't tried the maggy since, the motor has run for about 3 hours on the magneto up till now. Just out of curiosity, how do I access the condensor in those G4 magneto's, because the points look almost new.
thanks
Mike
Thu, Jan 10, 2013 5:05 AM
chriscokid
Thu, Jan 10, 2013 5:53 AM
ag-mike
Reply to chriscokid:
maybe this will help: http://www.oldengine.org/members/diesel/Eisemann/MagData.htm
mike, this is off topic of ur disk question which i think is ur problem. but anyway u gotta watch those old Eisemanns, my experience is that most out there has old weak coils. my Eisemann 2 cylinder pony mag will start the engine but the coil goes bad after about a minute, stalls and not enough running time to start the diesel. wait a hour and half and it'll start again and run less than a minute. i talked to a mag guy and he said get a aftermarket wico mag or put about 500.00 into the Eisemann rebuild. good luck.
ps i'm going to put some other mags on ebay, some have spark and some don't, i'm going to list saying; " exact condition unknown because it can have spark by hand but when mounted on engine it may not run as it should."
Thu, Jan 10, 2013 6:55 AM
Mike Meyer
Reply to ag-mike:
Thanks for your quick feedback, I agree those Eisemanns can be tricky, I had a RC-2Q on one of my "new" RD6's that I'd gotten checked over by a old maggy guy I use and he said it was hot and ready for action after he fitted a good secondhand coil, and I fitted it back to the pilot motor with new Autolite plugs and wires, and on the second pull on the crank it tried to fire the motor, so I thought, "you beauty, here we go Mikey Boy, 20 years of sitting outside in the weather and this Ol pilot motor is going to start the RD6!!"
Well, for the next 4 hours I cranked and cranked and cranked and cranked till my hands were covered in blisters, and rechecked the timing, and recleaned everything, because it would spark on the plugs outside the motor, but once I put those new plugs into the motor (and tried other new and old plugs too), I discovered eventually the maggy would not produce a spark under compression, and I've had that problem before on motorcycles too. So I sent the maggy back to my maggy man and after he fitted another coil everything was good.
So back to this rotten G4, you want to know what I just discovered, the points are opening on their own without even hitting the timing blocks in the timing ring!!!! Yep, I just was looking at the points really closely because I have them set at 12 thou, but those old maggy's are often worn more on one timing block, or the timing ring itself gets worn from "hanging" on the maggy vibrating away in dusty conditions, so it's impossible to get 12 thou equal on both blocks, but anyway, this little devil is actually somehow openning those points the slightest bit, about 2 thou, for nearly the entire rotation between timing blocks, even with the timing ring removed, so the points are only closing for about 5 degrees just before they should be opening as they hit the timing blocks!
Is that weird or what, because there is very little movement or slop in the armature bearings, and the timing ring is not worn, the points look almost new to me and theres no sign of obvious damage. Man o man, these old Cats sure through some weird curve balls at a dork like me, and even when the points are opening ever so slightly without hitting the timing blocks, I'm unable (yet) to gently push them closed with a screwdriver, so there must be some weird flexing going on for them to open on their own, even though I can't see it.
I'll keep at it, onwards and upwards.
regards
Mike.
Thu, Jan 10, 2013 7:54 AM
Reply to ag-mike:
Hi Mike,
from memory the big gear should have both an L and an R on it for left or right hand rotations.
This timing is not super critical for the best spark.
That having been said, this timing puts the brass contact segment in the optimum position for the brush to pickup the spark in the range of full advance to full retard.
The scan below from the 2Ton OMI should explain and show the timing positions of the dots, letters etc.
Have checked the left overs in the shed and can see that the marks on the big gear are very faint and you need good sunlight to see them--maybe a magnifying glass.
On the right scanned page is a good list of maggie problems--this also goes to the next page of your OMI on disc I sent you years ago.
Another thing if you need to tow it, your impulse coupling may not have enough end clearance and cannot wind up and release cleanly for a good spark---over oiling the coupling causes tardy op too.
Other factors can be establishing the correct amount of choke and throttle stting for a good start from cold or hot, idiosyncrasies of machines vary--maybe a tight inlet valve lash, air leak in inlet track etc. can be factors to cause hard starting along with many other little problems/deficiencies.
Hope this helps.
Thu, Jan 10, 2013 7:59 AM
Mike Meyer
I checked that site yesterday and for some reason they don't list the G4 series, unless my male blindness is worse. The problem with restoring these old Cats is I often never know what was original fitment, and what has been fitted at a later date, ratted off another tractor, or even a completely different make, like in the case of the distributor disc.
regards
Mike
Thu, Jan 10, 2013 8:01 AM
Reply to edb:
Hi Mike,
Hope this helps.
Hi Mike,
MMmmm, good observation there Mike, I have had points before that were tight on their pivot post. They would rattle closed and bounce of the cam and stay partly open, as you are finding.
I dismantled the points and polished the post with some super fine worn out wet or dry paper. Lubed the points fibre with CRC and had success.
Keep at it and you will soon be the Eisemann expert here.
Another thing to check is that the return spring assembly has had the second leaf fitted correctly--one end is bent back slighly to stop it digging into the main leaf when in the tensioned condition. From memory if it is fitted on the wrong side of the main leaf or back to front it can cause detensioning or binding of the main leaf.
Eddie B
Thu, Jan 10, 2013 8:08 AM
Mike Meyer
Reply to edb:
Hi Mike,
Hope this helps.
[quote="edb"]Hi Mike,
Hope this helps.
Eddie B.[/quote]
Thanks for the scans, my large gear has both a R and L stamped on it, my concern is the smaller distributor disc also has a R clearly stamped in it, but they are about 150 degrees apart from each other, and with only 3 screws to mount those distributor discs onto the gear, there is no opportunity to adjust that situation. This self opening of the points has me puzzled right now, so I'll report back in awhile if I find a cause, because unless I'm mistaken the points should be closed for about 340 degrees of the armatures rotation, opening only briefly for about 10 degrees each time they hit both timing blocks on the outer timing ring, or have I got that wrong?
thanks for your help
Mike
Mike Meyer
Reply to edb:
Hi Mike,
Eddie B
Eddie B[/quote]
Will investigate more, the points flat blade spring is in good condition and keeps good tension on the points, and the pivot post is not worn, but even so those points are opening themselves from about 1 till 5 o'clock, and again from 7 till 11 o'clock, closing ever so briefly just before hitting the timing blocks at 12 and 6 o'clock. Very weird, I'll put the devil of a magneto on the kitchen table while I have lunch and think while I chew!😆 Thinking beats talking in my case, as you know.
Cheers
Mike
Thu, Jan 10, 2013 8:14 AM
Reply to Mike Meyer:
Hope this helps.
Eddie B.[/quote]
Mike
Hi Mike,
do not sweat the gear/ segment timing marks too much, the critical thing is the segment relationship as shown in the scan.
If you set the points just opening or just against the block as per the scan and, with the advance and retard rotation of the housing with the blocks in, set at halfway, then the pickup brush should align to the middle of the brass distributor segment, also as shoen in the scan.
Thu, Jan 10, 2013 8:19 AM
Reply to edb:
Hi Mike,
Hi Mike,
something not adding up here.
The two points blocks I recall in the removeable ring are about 3/8" long and 1/8" high so I am at a loss to see what else can open them without eyeballing the iron.
Are the points self opening even with the cam ring removed ??? If it is then something is maybe dragging on the back of the points mounting plate
Do you have anything more than the merest amount of end float in the armature bearings ?
If the armature was not orientated in the maggie body correctly (for and aft) or the tapered bore for mounting the points carrier plate into was split at the keyway--have seen it-- or the points plate was missaligned by having the key that is punched into its centre, was not engaged in the keyway of the armature, could somehow cant the points plate and cause the self opening????
Scan bleow should give you a good idea of parts location/orientation for the points mount plate etc.
If the points mount plate was hard up against the maggie main housing, too far forwards, the screw holding the points pivot pin on was rubbing--it is not a very solid mount as the screw is thru an insulated washer thingo-- it could be wobbling as it rubs and cause the problem--kinda thinking silly stuff out loud, BUT, this thinking out side the square has solved many of the problems I fixed at the Dealer after others could not find the problems.
Maybe give me a bell and we can kick it about.
Thu, Jan 10, 2013 9:33 AM
