Bung wrenches
Bung wrenches
jonstark
Send a private message to jonstark
I need the wrenches for the various plugs for servicing. They are internally wrenched hexes of differing sizes.
What are they called?
Where can I find the ones that I need?
Anyone have extras to sell?
thx,
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Wed, Dec 5, 2012 4:47 AM
STEPHEN
Look on the ACMOC store under restoration parts.
Wed, Dec 5, 2012 5:50 AM
Mike Meyer
Thank you received: 6
Reply to STEPHEN:
I've seen that guys handiwork who is making the Cat. bits and pieces being sold in the ACMOC Store, its all first class, we are lucky he is going the extra yard for us.
regards
Mike
Wed, Dec 5, 2012 6:23 AM
Rennix
Send a private message to Rennix
Reply to Mike Meyer:
regards
Mike
I'm glad you fellas point out that they can be bought from acmoc. I was getting ready to order one on ebay. Thanks for the reminder.
1953 D4 6U8588 Cat hyd. blade, Hyster D4 winch
1959 955 Traxcavator 12A6595
1959 Rogers/Phelan 25 ton lowboy
1960 D7 17A14922
Wed, Dec 5, 2012 7:50 AM
Mike Walsh
Reply to Rennix:
If you have the ability to weld a nut on a bolt you can make one yourself.
If you need the standard 1 3/16" tool, use a Coarse Thread Metric M20 bolt x 50 mm long. It has a 30mm head that gives you the 1 3/16. CAT Part No. 6V3531. I remember someone else on the BB bought one from ACE Hardware.
Thread a 7/8" NC nut onto the bolt and weld it in place. CAT Part No. 2J3505.
You might want to shorten the bolt a bit before you weld it up. Thread the nut on and see where the tool balances for you. Use an impact to remove those dry plugs that are rusted in place and a flex handle to remove those backed by oil so you don't get a bath when the plug spins out faster than you can stop the impact.
Some folks just weld a piece of bar stock on the threaded end of the bolt and wrench them out but the impact and flex handle are much easier to use.
Wed, Dec 5, 2012 11:24 AM
Jack
Reply to Mike Walsh:
Just DO NOT USE A PIPE WRENCH. I just got through refacing a leaker. The pipe wrench upset enough metal to make facing in the lathe necessary and now it is hardly an unblemished OEM part! That's what you sometimes get from the tractor junk yard.
I use a nut welded onto a flat steel plate with a square hole in the middle for a 1/2 socket drive. Carries nice and compact in my tool box.
Wed, Dec 5, 2012 1:17 PM
Reply to Jack:
Do not use a Cold Chisel either!
Those bunged up Plugs leak worse than the Pipe Wrenched ones!
There was an extensive thread on this subject this past spring/summer where a lot of the guys contributed photo's of there homemade favorites!
Wed, Dec 5, 2012 6:39 PM
King of Obsolete
Reply to drujinin:
since i live at the end of the world, i use homemade cat wrenchs. i'm also colour blind so that is why they ended up painted john deere green, lol.
thansk
KoO
Published Author
Thu, Dec 6, 2012 6:56 AM
D2Don
Send a private message to D2Don
Reply to King of Obsolete:
thansk
KoO
Published Author
I bought mine from the local Cat dealer.
Thu, Dec 6, 2012 8:23 AM
