9U D6 Water Pump Parts Availabilty
Showing 1 to 7 of 7 results
Woody
Send a private message to Woody
Question for Old Magnet? How availble are parts, / gaskets, etc, for a 9U D6 SN #9U27566? I was in the shop the other day and notice a small amount of anitfreeze on the floor, getting under the tractor it appears its coming from the water pump. Closer inspection will involve pulling the hood to get a good look at it. Tractor has a hardnose on it, therefore that makes it a little more difficult to see where the leak is.
One last question how sucessful have you been in using a spanner wrench to undo the fan hub, I remember reading that the holes where the clips fit to adjust the belt a spanner wrench can fit in there?
Have not called Western States Cat yet, but any parts sources would be appreciated.
Thanks much
Woody
Tue, Dec 4, 2012 6:29 AM
Hi Woody,
I'm not aware of any problems getting water pump parts.....but I haven't bought in awhile.
Spanner works good for adjustment but not busting loose a froze up hub.
Tue, Dec 4, 2012 7:14 AM
If you're needing to move the adjustment on the fan pulley, take the lock bolts and tabs out and then use a short extension from a socket set, or a 1/2" bolt about 2.5" or 3" long and put it between the back of the pulley and a bolt or other knob on the front of the water pump. Grab fan blade with other hand and put pressure on it so it is caught. Then you can really put some pressure on the asjustment nut. I used to try to use a hammer and a drift on them and every one I have ever seen has been treated this way, but you can usually do a lot more just pulling on the fan blade.
It may be obvious to you, but do not remove the back of the water pump housing, only take out the front part with the impeller,shaft and hub in it. There are some really challenging bolts holding the rear part of the housing onto the head and the block!
Tue, Dec 4, 2012 7:29 AM
Thank you received: 16
Regal had the repair kit available a year or so ago at a better price than from Cat.It had everything you would need except for a impeller.Hopefully you will not need one of those because that was a Cat only part,and they think it is gold plated.
Ray
Tue, Dec 4, 2012 8:40 AM
Oil Slick
Reply to Ray54:
Ray
Ray, if you do need an impeller and you can't find one elsewhere you'll be happy Cat still has parts available......even if they are gold plated.
Tue, Dec 4, 2012 1:40 PM
Woody
Reply to Oil Slick:
Hey Guys,
Thanks for information and advice, great stuff as usual. The fan belt adjustment with the two hubs wasn't one Cats better ideas, they changed that on the 28,000 series 9U's to a double V- belt with a idler tighner. I would buy one of those in a heart beat if lucky enough to find one that was being parted out. Way back my Dad almost bought a 1959 D69U, they made quite a few suttle changes that year prior to coming out with the D6B.
I will let you know what the source of the leak is once we get her opened up a little more. Thanks again for the posts, this a great sight for old Cat lovers like myself.
Best,
Woody
Wed, Dec 5, 2012 12:55 AM
Reply to Woody:
Hey Guys,
Best,
Woody
Yes, they finally fixed that lousy design....been looking for years to get that upgrade.....only ever saw one and got the pictures.
Wed, Dec 5, 2012 1:56 AM
Woody
Yup your pictures are what the unit looks like. I have only ever seen one myself, that particular machine also had hydraulic track adjusters on it as well, not as big a deal as the upgraded fan belt adjustment but nice to have.
Sat, Dec 8, 2012 2:25 AM
