Internal Engine Cleaning
Showing 1 to 10 of 13 results
janmeermans
Folks,
When I open up the valve covers on my FIFTEEN, I see 1/8th inch thick, black sludge or goo covering everything in sight. When I dropped the oil, I stuck my little pinkie into the oil drain and could feel similar deposits on the bottom of the oil pan. What to do?
Has anyone used a product like CRC's Engine Cleaner (or similar) to clean up 80 years worth of sludge? Just wondering how that turned out. Of course the right answer is drop the pan and use degreaser to clean everything up but that is a lot of work. Another BB member here thought if I continued to use non-detergent oil, I could probably get away with doing nothing. Thanks in advance.
Jan
CAT 15 PV 7207
Wed, Nov 28, 2012 9:38 AM
STEPHEN
five gallons of paint thinner and a pressure siphon/venturi gun is what I use. No smoking!😆
Wed, Nov 28, 2012 9:58 PM
janmeermans
Reply to STEPHEN:
Stephen,
I like your answer. That saves a lot of work. Do you do anything to aggitate the thinner while it is in the pan? Do you do several cycles using the same thinner, perhaps strainning it each time before re-using it? -Jan
Wed, Nov 28, 2012 11:47 PM
4D2Ken
Send a private message to 4D2Ken
Reply to janmeermans:
Stephen,
My D2 service manual mentioned some type of engine flushing fluid that CAT uses. As I recall you drain the oil and then replace with the flushing fluid, start the engine or maybe just spin the main with the pony for five minutes then drain the flushing fluid out. Anyone ever tried this?
Thu, Nov 29, 2012 3:43 AM
Delta Dirt
Send a private message to Delta Dirt
Reply to 4D2Ken:
Flushing and cleaning may be OK--------but switching to a high detergent oil behind non-detergent usually brings on a high rate of oil consumption.
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Thu, Nov 29, 2012 3:54 AM
bob
Send a private message to bob
Stephen,
[quote="janmeermans"]Stephen,
I like your answer. That saves a lot of work. Do you do anything to aggitate the thinner while it is in the pan? Do you do several cycles using the same thinner, perhaps strainning it each time before re-using it? -Jan[/quote]
Jan, you didn't say if you plan to clean and overhaul the engine. If you are planning that, mix half old coolant with the engine oil and idle it up untill it gets hot. That will slush it out, maybe repeat a couple of times, don't load engine, maybe just take filters out and wash off then run again, they will collect a lot. After the sludge stops comming out put in new filters and oil and work it a bit but listen for any knocking sounds. If it works good and holds oil pressure, drop the pan and check the crank bearings. That may be all it needs.
Later Bob
Thu, Nov 29, 2012 4:37 AM
STEPHEN
Reply to bob:
Later Bob
Jan, we have a chain store here that sell cheap junky tools from China. I bought a siphon wand that has a connection for compressed air and a hose to drop into a bucket of your choice solvent.
1)Remove all drain plugs and inspection covers.
2)Manually remove large deposits
3)Put a large container under the drain hole to capture as much solvent and filth as you can
4)Donn protective gear like dish washing gloves , eye protection
5)"go to town " spraying the solvent everywhere you can
6) "wash, rinse & replete until satisfied
Thu, Nov 29, 2012 6:10 AM
willwingo
Reply to STEPHEN:
The post above suggesting putting "half old coolant" in the oil and running it until it is hot is really bad advice. Don't do it.
Thu, Nov 29, 2012 8:24 AM
ag-mike
Reply to Delta Dirt:
Delta Dirt
[quote="Delta Dirt"]Flushing and cleaning may be OK--------but switching to a high detergent oil behind non-detergent usually brings on a high rate of oil consumption.
Delta Dirt[/quote]
plus alot more crap flowing into the oil pan and filters. i'd remove inspection covers on the pan if it has any or remove the pan and clean. my d13000 had inches of crap in the pan nearly choking off the pump screen. it had covers and i made good use of 3" putty knife and plenty of rags with paint thinner (menards = cheapest). i also pulled and cleaned the screen. i'm glad i went this far with the effort and time every time it runs i'm confident its getting oil like it should. its 1937 and i don't think the pan was ever off or cleaned. good luck.
Thu, Nov 29, 2012 9:08 AM
Reply to ag-mike:
Delta Dirt[/quote]
No tricks that I know of either, just plenty of work with solvent and "lint free rags" and scrapers. Not like one guy I knew with the flathead Fords that would set them on fire to burn out the gunk (with engine out). Still use that method to clean off the oil pump pickup screens though.
Thu, Nov 29, 2012 10:14 AM
ag-mike
won't that melt any solder used in the fabrication of the screen assembly? it wasn't that hard to remove the bell and clean.
Fri, Nov 30, 2012 4:23 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
