955H Recoil Spring Length.
invisabledog
Send a private message to invisabledog
I have a question for the much more experienced Catophiles. I purchased an aftermarket recoil spring to replace a broken one on my 955H. The relaxed length is approximately 1 inch longer than the manual calls for, I can compress this down to the required installed length, but will this be a problem? The coils will not bind. I could also relocate the front mounting brackets forward an inch and install at the 1 inch longer compressed length. What do you all think? Thanks in advance.
Mon, Nov 26, 2012 1:11 AM
Recoil springs are preloaded either by an internal bolt or compressed by a bolt until installed and then the tension released so the spring fits the track frame.
Only ever dealt with the old style where the internal bolt holds the length. Have one with the bolt broken on our 9U that I have welded stops on the track frame so it doesn't extend too far.
Mon, Nov 26, 2012 1:34 AM
I installed an after market recoil spring on my 941b. It was a little bit longer than what my book calls for but after a little research (from the company that sold it) it's spring constant value was a little less than Cat's so when installed it would give the same load on the idler. Seems to work fine. The spring I took out had been cracked in three places for over 20 years so I'm sure it had much less resistance than spec.
Mon, Nov 26, 2012 1:42 AM
Reply to dpendzic:
On the "H" models spring compression is limited by the sleeve on the spring bolt. If you can get full retraction without bottoming the coils it will probably work ok. Extending the stop mounting location will come at the expense of lost hydraulic adjuster travel and may interfear with service work or the ability to retract the front idler enough for track removal.
Mon, Nov 26, 2012 2:33 AM
invisabledog
Thanks all. Going to put the spring back in the press and go for the last inch. It's nerve wracking, working with all that pressure, but the nut is on the rod so it can't go anywhere. Once this is done and the idler is back on, I can install the new chain and be done. With this side.
Mon, Nov 26, 2012 4:57 AM
Reply to invisabledog:
I always installed 2 nuts on the spring bolt when handling the spring for installation--felt much more safer knowing the spring force was 10 tons or more! :jaw:
Mon, Nov 26, 2012 7:42 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
