D2 n hyster winch cost
Showing 1 to 10 of 11 results
mog5858
hey guy's need help what is the going rate for a winch for my d2 i found one but the guy said 3000.00 and i still have to pick it up and remake the controls and handles. that's more than i paid for my cat is that what thay are worth? really would like to use my logging arch i got just the right size but need to get a winch frist. it dose not have to be a hyster just they look good. open for idea's thanks
Wed, Nov 21, 2012 11:34 AM
Inter674
seems expensive for the USA, but then again the D2's are cheaper there than here, so the overall cost is lower I guess.
A winch to suit a D2 in Aus would be 1. very hard to find and 2. very expensive - some say over 2500Au dollars. But so far I have not seen any for sale that are worth buying.
I have an Aussie-build one on my D2 that fits real good though😊
Wed, Nov 21, 2012 12:07 PM
Dan Pratt
Reply to Inter674:
One for sale now on the Portland OR craigslist for 1500.
http://portland.craigslist.org/clc/grd/3379144643.html
Dan
Wed, Nov 21, 2012 12:21 PM
Reply to Dan Pratt:
Dan
I'd say $1,200 to $1.500 is more in line unless it's been completely rebuilt.
That also has to include all the controls and mounting brackets.
Thu, Nov 22, 2012 1:07 AM
bernie
Not sure if this is apples to apples, but I sold the PCU off my D4 winch three years or so ago for $400 pick up at my place. Fellow was restoring a military D42T with cable unit and needed it to complete his machine to make it functional. May have been able to get more, but who knows. He was from Pennsylvania-never did send me any pics.
I'll reinstall my winch at some point-still need the top-cover where the PCU rested.
Thu, Nov 22, 2012 1:34 AM
Inter674
Reply to bernie:
D4 winch in Aus will cost up to 2 grand, eg., a D4D Hyster. A D2 winch in good nick is likely to cost more as there are fewer of them and the main reason for fitting them appears to be for better machine balance and appearance rather than for dragging stuff.
Interestingly, the D4 7U machines I've seen that have had winches fitted have nearly all had cracked rear transmission cases. One of my wrecks also has a severe twist to the internal PTO spline/shaft. This is clear evidence of severe abuse.
Thu, Nov 22, 2012 2:42 AM
4D2Ken
Send a private message to 4D2Ken
Reply to Inter674:
Does a D2 winch require a PTO to operate?
Thu, Nov 22, 2012 2:43 AM
Inter674
Reply to 4D2Ken:
yes, it needs a power source from the gear box.
Thu, Nov 22, 2012 2:47 AM
Reply to Inter674:
Not a "PTO" in the sense of a rear mounted one, but it needs the shaft that comes out of the winch that goes up inside the transmission/final drive case to connect into the transmission drive shaft.
Thu, Nov 22, 2012 4:08 AM
n7gxz
Send a private message to n7gxz
Reply to 4D2Ken:
The Hyster D2 and D2N do not need a seperate PTO, they have a shaft that couples with the lower (counter) shaft in the transmisssion. I picked up a D2N about 4 years ago for $1500 USD.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Thu, Nov 22, 2012 4:11 AM
chriscokid
Reply to n7gxz:
Kevin
Here is the parts and instruction book for a D2N Winch.
It might help answer any questions you may have.
http://www.alliedsystems.com/pdf/Winch/Manuals/599228W.pdf
Thu, Nov 22, 2012 4:15 AM
