diesel 40 governor setting
d50dave
Send a private message to d50dave
I was wondering if any of you could tell me how to set the governor speeds on my diesel forty. I would like to run the rated speed up to about 950 RPM for use on our sawmill. I don't think that should be a problem since Caterpillar ran a Nebraska test at both 850 and 1000 RPM. I also have a diesel fifty I would like to slow the idle speed down a little. Thanks for any help. Dave
Sun, Nov 18, 2012 10:19 AM
scanned below is all the Early Diesel Engine Gov. Setting Data I have.
It is taken from the Serviceman's Reference Book on Caterpillar Diesel Engines, Form No 5060B, dated 12-47.
Shown is the first generation stuff, and the second generation stuff for future reference as needed by others in future--Grab 'em now while they are up.
Hope this helps.
Mon, Nov 19, 2012 9:26 AM
d50dave
Reply to edb:
Hope this helps.
Thanks for the information , Eddie. That's just what I needed. -Another question- I have a pulley on my Diesel Forty that was originally on a PS series Thirty. The pulley has a brass plate on it that says to periodically put the transmission in high gear and operate for a few minutes to lube the transmission bearings. Do you know if that is necessary on the Diesel Forty since the transmission design is quite a bit different. Thanks again. Dave
Tue, Nov 20, 2012 9:26 AM
Sasquatch
Reply to d50dave:
Yes, the lube procedure applies to the Diesel Forty too. A little while ago I finished going completely through this belt pulley drive that is specifically for the Diesel Forty/RD6 machines and it has the same instruction tag on it as you mentioned is on yours. I can't quote it word for word, but it goes something like "put the machine in gear and hold both steering clutch levers back, then engage the main clutch for 2-3 minutes to lubricate the transmission gears." I remember thinking, "how many arms and hands does it take to do all that at the same time?"
[img]http://i802.photobucket.com/albums/yy310/TRNelson/RD6%20belt%20pulley/076.jpg[/img]
[img]http://i802.photobucket.com/albums/yy310/TRNelson/RD6%20belt%20pulley/005.jpg[/img]
[img]http://i802.photobucket.com/albums/yy310/TRNelson/RD6%20belt%20pulley/005-2.jpg[/img]
Tue, Nov 20, 2012 10:15 AM
