Liner removal and istallation?
Showing 1 to 6 of 6 results
951c
Send a private message to 951c
I was reading the thread with the older man ,using what seem to be a right-handed metric pipe. Do you guys have pics of the whole job ,removal and installation the tools etc. ? Anything help on tools or tricks!
I'am sorry, the 3304pc 78p4609 and 86j3848 .
Fri, Nov 16, 2012 4:36 AM
You need a cylinder liner pulling set. Shop manual recommends putting something over each crankshaft throw to protect it as you pull the liners. Of course you may already have the crankshaft out by that time, that's even better. There is usually quite a bit of debris in the bottom of the water jacket that will be dislodged as the liners are pulled.
Have you removed any bearings yet?
Fri, Nov 16, 2012 5:50 AM
951c
[quote="ccjersey"]You need a cylinder liner pulling set. Shop manual recommends putting something over each crankshaft throw to protect it as you pull the liners. Of course you may already have the crankshaft out by that time, that's even better. There is usually quite a bit of debris in the bottom of the water jacket that will be dislodged as the liners are pulled.
Have you removed any bearings yet?[/quote] No nothing yet? At first I was going to pull the motor but I'am going to do a in-frame . i have begun on the belly pan and ran out of time ! The machine is 200 milles from my house . I'am in Ct. and the machine is by Utica ,NY.. I just talked to my friend and now we may postpone until spring. I ask my questions in advance because I take notes to bringwith me up north and have limited access to everything . How much is a puller ? Ido'nt know hereI would borrow one.
Fri, Nov 16, 2012 7:55 AM
Usually can't fix what's wrong on one that did what you describe with an in-frame overhaul. Drop the pan and remove rod bearing caps to look. Then make further plans.
Fri, Nov 16, 2012 8:03 AM
951c
Gotchya Thanks. Are you refering to crank damage ?
Fri, Nov 16, 2012 8:13 AM
Yes.
Got a tractor here sitting outside the shop that is in about the same situation. Sounds as if the crankshaft has a bad bearing, maybe a main????, but won't know for sure without dropping the pan and the bearing caps.
Unfortuntately it will be parked in the weeds if the crank is the problem. A piston or sleeve problem, we might fix it.
Fri, Nov 16, 2012 8:29 AM
Yes.
I believe it was a piece of thick walled 1" square tubing radiused to fit the edges of the sleeve underneath?
A piece of "All-Thread".
On top, I used another piece of square tube blocked up with some cut-off pieces sitting on the block.
You only need to pop the seal loose.
I went though dozens of mechanic tool websites for prices, but could not justify limited usage verses cost.
BTW
Some AutoParts stores rent specailty tools.
Sat, Nov 17, 2012 7:22 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
