Fuel pump diaphragm for cat 22
Showing 1 to 10 of 10 results
22Catter
Send a private message to 22Catter
Does anyone know of a source for a fuel pump diaphragm for a cat 22. The fuel pump is an AC brand . Hopefully there is a supplier in the western half of the states. I also need a heat gauge as mine has died. I understand cat sells a replacement that is smaller .Does anyone have that part number ? Thank you for any help Don
Thu, Oct 4, 2012 6:40 AM
Mike Meyer
Contact John or Jim Matta in L.A for the 22 diaphragm, they are about $5 each from memory, I'll PM you his phone number, the part number for the heat gauge is 4B0152 according my Parts book.
regards
Mike
Thu, Oct 4, 2012 7:26 AM
Thank you received: 10
Reply to Mike Meyer:
regards
Mike
[quote="Mike Meyer"]Contact John or Jim Matta in L.A for the 22 diaphragm, they are about $5 each from memory, I'll PM you his phone number, the part number for the heat gauge is 4B0152 according my Parts book.
regards
Mike[/quote]
Mike can you pm me too please.
Neil.
Thu, Oct 4, 2012 8:48 AM
Old_n_slo
Send a private message to Old_n_slo
regards
Mike[/quote]
Neil.
If your sources for a factory fit dont pan out, try Olsons http://www.olsonsgaskets.com/
They might have a direct fit for your pump, or fuel resistant gasket material in a flex format. I have successfully used their sheet gasket material in an accelerator pump application for an obsolete Solex carb. This is a fabric reinforced material just like fuel pumps and accelerator pumps use, and comes in various thicknesses.
Good luck!
Thu, Oct 4, 2012 9:38 AM
Peter C
Send a private message to Peter C
regards
Mike
regards
Mike[/quote]
Mike, I am looking for a fuel pump diaphragm for a 22 also. Can you send Jim Matta's number to me also?
Pete Oswald
Thu, Oct 4, 2012 11:15 AM
Bones2
Send a private message to Bones2
Reply to Peter C:
regards
Mike[/quote]
Pete Oswald
Hi
Can someone please send me the contact details for the source mentioned above, or current alternative
thanks
Tony
Fri, Jan 3, 2020 4:09 PM
Reply to Bones2:
Hi
thanks
Tony
You want to contact "Then and Now at 1-781-335-8860".
Google their webpage. They will send your pump back to you totally rebuilt and updated if requested. US price is $135(approximately). Typically they get them done in about a week
Fri, Jan 3, 2020 8:02 PM
restore49
Reply to drujinin:
Is this just a diaphragm or does it have a pin in the center. If just a disk I have a roll of 1/16 " reinforced flexible material I have used for fuel pumps - your more than welcome to try a piece. Bob
Fri, Jan 3, 2020 9:21 PM
GrantJ
Reply to restore49:
While you are waiting for a fuel pump, bypass the pump. make a cover plate and drive the tractor. I have been told that unless you are in steep hill country it will run just fine without a pump. I have a tailseat 22 with no fuel pump and it "ran when parked". Maybe make sure the fuel tank is full for an extra 1/4 pound of fuel pressure. Good Luck with it. Grant.
Sun, Jan 5, 2020 2:08 AM
bruce oz
Reply to GrantJ:
https://classiccarbs.com.au/image/cache/data/Products/Fuel%20Pump%20Kits/900_757KT-Fuel-Pump-Kit-003-500x500.jpg
https://classiccarbs.com.au/index.php?_route_=Fuel-Pump-Kit-Ford-V8-1955-61-with-dual-action-fuel-vac-pump-has-10-locating-screws-suits-fuel-side-900.757KT-
Ford v8 , 8 bolt Diaphragm fit I think ,
Sun, Jan 5, 2020 3:56 AM
Reply to GrantJ:
Mine has the "Dual Fuel" style of Tank. While waiting for my Fuel Pump Rebuild Funds to build up, I drove mine a lot with just the "Gas Starting Tank"! Carried a 2 gallon jug on the fender to add a little every once in a while. That tank is lower in the main tank so going up grade it would lean out and stumble.
Tue, Jan 7, 2020 8:16 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
