955 parts interchangeable
charles walton
Send a private message to charles walton
Can anyone tell me where I can find out which 955l parts are interchangeable with other serial# I have a 13x and I am looking to buy a parts tractor.I know that the 57m and 8y are basically the same machine but I'm wondering if some k model parts might work.
Sun, Sep 30, 2012 11:03 PM
rjh-md
955k engines are eariler D330 engines, scroll fuel injection 4.5 bore ,13x models have 3304 ,4.750 "engines with spacer plate block and sleve metering injection systems. torqueconverter transmission basically same ,sterring clutches same ,final drives different at board bearing support ,not sure about inner gear ratio
955k has 6.91" undercarriage ,955l,13x has 6.5 " pitch D6 undercarriage
This is from memory!
Mon, Oct 1, 2012 11:04 PM
Reply to rjh-md:
Early K's are 6.91 pitch, late K's/L's (85J10129-up) and 13X's are 8.00 pitch.
Mon, Oct 1, 2012 11:32 PM
rjh-md
Yes , 13 X has 8" pich or D6 10K undercarriage
If memory serves my right I think that all 955k ,and 955L,s up to the last 85J ,had 6.91 " undercarriage .the only 955's with 8 pitch undercarriage was the 13x
I remember that when the 8"pitch was interduced on these tractors ,ther was a steering clutch slippage problem ,and an extra disc had to be added to each steering clutch
Tue, Oct 2, 2012 3:42 AM
charles walton
Reply to rjh-md:
[quote="rjh-md"]Yes , 13 X has 8" pich or D6 10K undercarriage
I remember that when the 8"pitch was interduced on these tractors ,ther was a steering clutch slippage problem ,and an extra disc had to be added to each steering clutch[/quote]
Thanks for all the info,I was wondering if the lever bars on the loader assembly would work,mine have a lot of wear and I was hoping to get a spare set that I could get machined to new specs and then just swap them out and not have a lot of down time.I have already been through the convertor,all the pumps including the injection,steering,transmision,hydraulic.New turbo and exhaust and it has nearly new bottom.Now I just need to tighten it up some and I would like to get some spares.
Tue, Oct 2, 2012 9:07 PM
