D4 7U Steering Clutch Question
Showing 1 to 6 of 6 results
Inter674
I have a late model D4 7U equivalent and the book says the steering clutch width should measure no less than 3 1/8" . Mine measure a little less than that but I know the clutches were replaced a few years ago and were working fine before the pull down. I also have a spare set from another machine of similar age that measures exactly the same as the ones in question. Each has 11 toothed disks.
I don't want to pull it apart if I can help it, and looking closely I can see friction material on each side of the plates.
Question: is the minimum width of 3 1/8" applicable to all 7U steering clutches, or just to the early ones? I know the early ones had more plates (12 I think) and presumably may have been thicker as they were rivetted, not bonded.
Thu, Sep 6, 2012 10:47 AM
Hi Inter674,
as announced in the June 11 1954 Service Magazine article the steering clutch has been improved.
The main change was a helical cut 8 splined hub and discs to suit.
In essence it states:-
The normal stack height thickness for the faced and steel discs of one clutch is :- 3 1/32"
The minimum worn stack height is :- 2 19/32"
It seems your clutches are right there for max. stack height.
From specs I have for the D4C 39A-40A
Max. average stack height for 11 new lined disc assem's. and 10 steel discs = 2.787" to 3.093"
Min. stack height = 2.63"
These specs seem to align with the later D4 U series clutches.
Fri, Sep 7, 2012 10:12 AM
If you have the clutch out of the tractor add more plates,it will be slipping very soon if you don't.I have never seen a metallic Cat plate pile up like the fiber ones,so I have used some very thin used plates as long as the drive teeth were not real shape.They lasted much better than I hoped.Were it says add one I used 2 or 3 more than original did.Was very nerves it would be to many as I couldn't find a maximum height,but it worked.A few days ago someone posted a chart with minimum as well as maximum height for the old Cats. It may have been on Antique Caterpillar Machinery Enthusiast rather than here. Good luck to you.
Ray
Fri, Sep 7, 2012 10:13 AM
Inter674
Reply to edb:
Hi Inter674,
[quote="edb"]Hi Inter674,
as announced in the June 11 1954 Service Magazine article the steering clutchhas been improved.
Eddie B.[/quote]
Wow, I knew this forum was good, but this rapid response has exceeded all my expectations, and saved me a heap of work. I feel confident to leave it be now👍
Thanks again.
Fri, Sep 7, 2012 10:18 AM
Reply to Inter674:
Eddie B.[/quote]
Thanks again.
I had been using this chart and the specs published by General Gear.
What is correct?????
Fri, Sep 7, 2012 9:24 PM
from my research (posted above) yesterday on this subject I determined that the chart OM has scanned above is correct for G, J, T, and early U Series machines with multi-fine splined inner drums and Rivetted lined discs.
With the change to the helical cut 8 splined inner drums and the Sintered bronze lined/faced discs, the Service Magazine article gives the NEW Specs for the Later style clutch, posted above.
My D4 6U1 to 6U9988 Parts Book shows a change of the following items from the former Rivetted lined discs, steel discs, and inner drum, to new sintered bronze lined discs, steel discs and inner drum at S/No 6U9782.
Sorry I do not have a 7U Parts Book to give you the change over S/No for the 7U machines.
Hope this helps someone in future.
Sat, Sep 8, 2012 6:41 AM
Reply to edb:
The 7U equivalent change occurred at s/n 26503-up.
Sat, Sep 8, 2012 8:30 AM
