Caterpillar Ten Final Drive and Transmission oil
Showing 1 to 9 of 9 results
dozerdude
Send a private message to dozerdude
Finally got my Ten running, and the oil in the tranny and final drives is like tar. Going to clean it with Kerosene, but the book says that the final drives and transmission both use transmission oil. Is this correct? I'm taking it to a local show this weekend so I want new oil in it. I'm thinking the final drives take gear oil not tranny oil but i could be wrong.
Tue, Aug 21, 2012 8:39 AM
Larry in phelan
Send a private message to Larry in phelan
Hi, I am sure there are some opinions that will be differ from mine but if I did not see any water or contaminates in it I would leave it alone. I removed some of that 400-600 weight tar out of a tractor to put nice clean oil in it and I ended up with noise that was not there before. Just my 2 cents😊 Larry
Tue, Aug 21, 2012 9:02 AM
MARCOTEN
Reply to Larry in phelan:
a new 90w oil is much too thin and will cause leakage aswell, so look for the 300 w oil.
Tue, Aug 21, 2012 7:47 PM
dozerdude
Reply to MARCOTEN:
Ok thanks for the info
Wed, Aug 22, 2012 8:29 AM
Reply to dozerdude:
Back in the Spring/Early Summer there was a Thread on the "GL" grades of Gear Oil, seems that if you do want to put in modern lubricant. Then you need to find the lower "GL" type with less phosphorus(?) as this will pit Bronze bushings.
Wed, Aug 22, 2012 5:51 PM
3J1Bill
Reply to drujinin:
I use "Sta-Lube multi-purpose SAE 140 Hyoid Gear Oil API/GL4". It is not corrosive to copper, bronze or other non-ferrous alloy bearings and bushing. Bill
Wed, Aug 22, 2012 10:45 PM
dozerdude
Reply to 3J1Bill:
You put that in both tranny and final drive?
Thu, Aug 23, 2012 11:28 PM
3J1Bill
Reply to dozerdude:
Yes, the transmission and final drives use the same type oil.
Fri, Aug 24, 2012 11:25 AM
dozerdude
Reply to 3J1Bill:
OK thanks again. I uploaded a picture, hopefully it worked. I have fixed the seat since the picture.
Fri, Aug 24, 2012 4:59 PM
Steve A
Reply to dozerdude:
Nice looking Ten, and I,m not just saying that cuz its in Michigan.
I agree on the Lube, its very hard to keep modern 90W in the final drives but like you i find the old lube (if you can call it that) like tar, I typically add some old gas, drive it around for a while before I drain it just so it will flow out.
Fri, Aug 24, 2012 5:45 PM
