Cat 28 Firing order
Cat 28 Firing order
Showing 1 to 9 of 9 results
Robhodges
Send a private message to Robhodges
Does anyone have the firing order for a Cat 28? We pulled the plugs to lube the cylinders but the wires got mixed up.
Thanks,
Rob
Sat, Aug 18, 2012 12:01 PM
All little Gas CATS have the same firing order. (10, 15, 20, 22, 25, 2😎
Its on a couple of previous threads, but seems like it is 1-3-4-2??
Sat, Aug 18, 2012 5:26 PM
Robhodges
Reply to drujinin:
Thank, I tired to search through before I asked but couldn't find anything. The 28 belongs to an older friend who also has a D4 with pony motor issues so we hope to start the 28 and use it to pull off the D4.
Thanks,
Rob
Sat, Aug 18, 2012 8:36 PM
bruce oz
Reply to Robhodges:
Thanks,
Rob
hello ,this will help ,bruce oz
http://s1109.photobucket.com/albums/h439/Bruceoz_Colyer/?action=view¤t=017-1.jpg#!oZZ22QQcurrentZZhttp%3A%2F%2Fs1109.photobucket.com%2Falbums%2Fh439%2FBruceoz_Colyer%2F%3Faction%3Dview%26current%3D023-1.jpg
Sun, Aug 19, 2012 5:45 AM
Robhodges
Wow, Thanks, I looked and looked but couldn't find an online manual. Now all I have to do is figure out how to access it. I'm only 57 so I'm not as savvy at computers as you old guys or as up on the old cats.
Many Thanks,
Rob New boy
Sun, Aug 19, 2012 7:07 AM
Reply to Robhodges:
Many Thanks,
Rob New boy
If it is not 1-3-4-2, then it is 1-3-2-4.
I need to post some photo's later today and will check back on this after I look it up.
Sun, Aug 19, 2012 6:30 PM
willwingo
Reply to drujinin:
From the Caterpillar Gas Tractor Restoration and Interchange Manual: "With the exception of the 2- Ton, all of the gas Caterpillar tractors have a firing order of 1-3-4-2."
Sun, Aug 19, 2012 9:20 PM
Reply to willwingo:
I realized yesterday after posting that there is the remote possiblity of the overhead valve being different.
I checked my GAS 35 manual and sure enough it is 1-3-4-2 like I posted originally.
Also it is listing number one as lower left, number 3 on upper left, number 4 on upper right and number 2 on lower right. (if memory serves me right)
Mon, Aug 20, 2012 6:09 PM
bruce oz
Reply to drujinin:
i wounder why sometimes
Mon, Aug 20, 2012 6:44 PM
Dandy Dave
Send a private message to Dandy Dave
Reply to bruce oz:
All inline 4 cylinder engines have one of two firing orders. The Cats and IHC's and some others are 1-3-4-2. The Ford Model T, A, Fordson tractors, and N series and a few others are 1-2-4-3. It makes sense if you look at it as the reverse of each other. Move the number one to the last digit and read the order backward and the engine will still run in balance. The main difference is in the way the cam is cut. If an inline 4 has has gears to turn the cam the timing will be one way, say the cam is ground to a 1-3-4-2 order. Take away the gears and put a timing chain and cog set and now the cam will run in the same direction as the crank rather than the opposite direction. Now the firing order will be 1-2-4-3. Think about it and it will come to you. Dandy Dave!
Tue, Aug 21, 2012 9:41 AM
| Hartley - South Australia
