Carburetor float material substitution
Showing 1 to 6 of 6 results
Larry
Send a private message to Larry
Is there any float material that can be substituted for cork that is ethanol resistant and will function in an old Zenith carburetor? Present one is done and I can't seem to find anyone that has a good one. Thanks in advance, larry.
Thu, Aug 16, 2012 7:51 PM
Mike Meyer
Check out "Restoration Supply Co." in California, they have a comprehensive catalog you can view via your computer, I'm sure I saw them list a new gas resistant foam like material for rebuilding carby floats.
regards
Mike
Fri, Aug 17, 2012 4:19 AM
Larry
Reply to Mike Meyer:
regards
Mike
Mike, many thanks for the info. They do have the material. It is called Nitrophyl. They also have other products that may be used on the old dozers, such as hose clamps, wire ends, etc. Thanks again, Larry.
Fri, Aug 17, 2012 9:08 AM
zootownjeepguy
Reply to Larry:
One of our customers at work* just gave me a Restoration Supply catalog. LOT'S of cool and hard to find stuff in there! ๐Ÿ‘
*(I built an adapter for his 1912 Buick to mount a distributor in place of the magneto)(I love doing cool stuff like that and getting paid to do it)(should had had him leave the car, you know that distributor mount should have been thoroughly tested :thumb๐Ÿ˜Š.
Rich Salvaggio
D2 5U9917
Fri, Aug 17, 2012 9:20 AM
Mike Meyer
Reply to Larry:
I just bought a heap of parts from them myself including the old style hose clamps and everything arrived safely here in Australia a few days ago and looks great, thanks to Mastercard and the USPS!
regards
Mike
Sat, Aug 18, 2012 4:01 AM
willwingo
regards
Mike
I made a pair of floats for an Ensign Aee carburetor using the Nitrophyl material
A few notes:
1. Restoration Supply seems to very good to deal with- very quick service;
2. The Nitrophyl material is very nice to work with, I machined it on the Bridgeport, but I think simple shapes could be easily done with hand tools;
3. Each float was about 10 gr lighter than the sealed cork floats I was using.
We are trying to solve a chronic "sticking float and flooding" problem- time will tell.
Wed, Aug 22, 2012 2:49 AM
t20dozer
Send a private message to t20dozer
Reply to willwingo:
A few notes:
Im have the same float sticking and flooding problem in my cat 25 ensign carb with the same material. i cant get it to straighten out. i think im going to put cork back in.
Wed, Aug 22, 2012 4:38 AM
| Hartley - South Australia
Newby Hall Tractor Fest
